Repeat the powerup test you made earlier, the readings should be the same If not check for solder bridges.
Take 1 Microcontroller from the component pile:
Fit it in the location marked here:
Make sure the dot marking pin 1 is in the right place (bottom left)
Solder carefully in place.
